This command configures the refresh rate for locally originated LSPs.
| area_name | Specifies the router process for which you are setting the LSP refresh timer. |
| seconds | Specifies the LSP refresh interval. The range is 1 to 65535 seconds. |
900 seconds.
This value should be configured to be less than the maximum LSP lifetime value, which is set with the configure isis area area_name timer max-lsp-lifetimeseconds command. Locally originated LSPs are purged and retransmitted at the specified interval regardless of link state.
The following command sets the LSP refresh timer for areax to 1200 seconds:
configure isis area areax timer lsp-refresh-interval 1200
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
